What's the sensitivity of that center and how loud do you like to listen to movies?
Originally Posted by chalugadp /t/1525125/3-way-center-channel-build#post_24550189
Could always go this route.Quote:
Originally Posted by nexxest /t/1525125/3-way-center-channel-build#post_24550182
I have been enjoying movies in 4.2 configuration for a while. MA BX2-s are undoubtedly great sounding speakers. But I think it's time to move on, to DIY land.
So I present you my 3-way center channel build:
As you may notice, it has:
1 x NeoX2.0 Silver
1 x Scanspeak 10F/4424G00
2 x Seas U18RNX/P
I already ordered the drivers. And I have 3/4" and 1" MDF. Friend of mine lets me use his CNC-machine to cut everything. In couple of weeks I will start building this thing (and if all goes well, matching left/right floorstanders aswell).
If you have any comments, please let me know. The size and shape of the cabinet is still undecided. Also, since a local DIY guy is designing the crossover for me, any guideline in that area is particularily welcome.
I will experiment a bit with this box calculation tool. F3 @ 84 Hz is not low enough.Quote:
Originally Posted by Martycool007 /t/1525125/3-way-center-channel-build#post_24550661
I can't help you with regards to the ideal box volume, but, I would go with a ported enclosure if it were me. I like the way that ported mains sound compared to sealed.
Absolutely, but there is a possibility that a friend of mine starts selling these (if they come out OK of course). That's why I picked X2.0/SS/Seas combo. To my knowledge, it hasn't been done before.Quote:
As I see it, X2.0 is newer, takes more power, has better horizontal and vertical dispersion. I have heard both, and they sounded the same to me. In fact, they sounded 95% as good as RAAL. And funny fact: X2.0 is 20€ cheaper than CD3.0.Quote:
Originally Posted by Martycool007 /t/1525125/3-way-center-channel-build#post_24551845
I wonder how the NeoX2.0 sounds compared up the NeoCD3.0 used in the Statements? Fountek recommends crossing over the NeoCD3.0 at 2,500 and the NeoX2.0 at 2000. I am not sure if using the Neo2.0 would be of any benefit over the NeoCD3.0 when crossed to a dedicated mid in a 3-way setup. I have heard the NeoCD3.0 in the Statement Monitors, and I personally thought that it was an outstanding performer.
Sealed or ported?Quote:
Originally Posted by nexxest /t/1525125/3-way-center-channel-build#post_24554830
Same drivers, vertical alignmentAnd perhaps 3 woofers, not 2.![]()
Could do satellites instead of floor standers. Could probably use them for your sides and rears too.Quote:
Originally Posted by nexxest /t/1525125/3-way-center-channel-build#post_24555359
I have always been "sealed" guy, but I guess it shall be ported. There are not many people who would buy a floorstander that has F3 @ 80 Hz.
Could fire the ports out the back. Instead only because you're then designing 2 speakers instead of 3. I personally prefer satellites, but I've built the Statements for a friend and they are quite awesome.
