Hi All.
Fully Active 3 Way Studio, Production, Home Theatre Speakers. These are built for High SPL with out sacrificing Sound Quality. Amplifier, Filter Cards and Speaker are all designed by Roger Quested.
I also have the Amplifier for these AP1550 with Fillter Cards Installed, Each Amplifier is configed in a Biamped Mode. I can Split the package if you dont require
the amplifier but highly recommend them as this was designed and configed for the LT20
The tweeter can be changed on these to give the speaker a shorter throw distance if required!!
What does the package Include:
3 x LT20 Speakers (With Original Box)
3 x AP1550 Amplifiers (Each Channel is Fitted with a Filter Card, One Channel for High& mid, the other for Bass)
Filter cards can be removed and you can run Electronic Crossover if you want too. However the Filter cards were installed
due to there natrual sound higher fidelity (Quested Opinion)
I can ship world wide by Fedex Air
Spec for LT20 Speakers Below
LT20-SP Semi-passive. High End Home Theatre Speaker, Can be installed anywhere high fidelity is required over normal PA Speakers
Built-in 2-way crossover between Low and Mid/High
High-power twin 10" speakers, 6.5" Mid, with Air Motion Transformer tweeter.
Freq Resp 40Hz - 18kHz +/-2dB. Dispersion 45 x 100 (rotatable HF baffle).
Continuous Max SPL: [email protected], [email protected], [email protected]
Size 580(w) x 685(h) x 440(d) mm. Weight 52kg.
Amplifier Specification:
2 Channel Class A/B Amplifier 774 Watts Per Channel In 8ohms, 1550 Watts Per Channel In 4ohms
For the complete Set: Speakers and Amplifiers.
For 3 x LT Quested Speakers Only No Delivery Included: $11,700.00 US Dollars
For 3 AP-1550 Amplifiers Only with no delivery calculated: $5,700.00 US Dollars.
I can ship World Wide by FedEx.
Payment Terms:
Bank Wire is Prefered.
Paypal is also accepted If you decide For Airshippment only. Paypal Fee has to be covered by the buyer at 4% of total transaction value.
Question or need more pictures you may PM or call me or whatsapp me first on +6281380094990
Pictures Below:
Payment Terms:
Pictures Below:
