I'm interested in putting a LCD outside under a covered patio.
1. Budget - Really don't want to spend more than $400
2. Seating distance - Between 5 - 14 feet away
3. Size/placement limitations - 32 inch LCD 720P (will be mounted in the ceiling of the patio)
4. Uses and sources - Outside under the patio, will be used mostly during the day. I will pretty much only use it for watching sports.
5. Room lighting - Since it will be outside, it will be pretty bright. (sunlight won't be directly on tv - since it will be under patio).
What other considerations do I need to look at? I really looking at either the
- Vizio v032oe
- Phillips 32pfl3504d
- Tosibiha 32av502r
Really can't seem to find any Samsung's or Sony's in the price range.
Any suggestions? I'm considering buying it at Costco since I can get a 2 year warranty as well.
- Vizio v032oe
- Tosibiha 32av502r
