1 - 20 of 25 Posts
Discussion Starter · #4 ·
^Yup. Since I'm happy with the games I can play on my setup despite some limitations, I obviously don't make too big of a deal out of artificial benchmarks.
Nice score BTW!
FWIW: P7739 3DMarks
3DMark ScoreP7739
Graphics score8051
Physics Score8287
Combined Score5570
GraphicsTest143.91 FPS
GraphicsTest241.68 FPS
GraphicsTest349.1 FPS
GraphicsTest421.21 FPS
PhysicsTest26.31 FPS
CombinedTest25.91 FPS
Default settings usedYes
EditionBasic
Screen Width1280
Screen Height720
Msaa Sample Count1
Texture Filtering ModeTrilinear
Max Af Anisotropy1
Tessellation Detail5
Max Tessellation Factor10
ShadowMapSize5
Shadow Cascade Count4
Surface Shadow Sample Count16
Volumetric Illumination Quality5
Ambient Occlusion Quality5
Ambient Occlusion Step Count4
Depth Of Field Quality5
Enable Window ModeOff
Enable Vertical SyncOff
Enable Triple BufferingOff
Enable WireframeOff
Color Saturation100%
Discussion Starter · #6 ·
^^^^ Looks like you're set for the next few years with all the bells and whistles!
Minor update for me with the latest 10.12 drivers: P3734 . 19 extra points = at least 30 extra frames I'm sure.
4662 for me. SLI doesn't seem to be working on this as I have 2 470s. Power consumption at full load for me is usually 575W, but this didn't break 450W. Tinker, what are you running with, and does SLI/XFire show in the results as ON?
ProcessorIntel Core i7-930 Processor
Processor clock3498 MHz
Physical / logical processors1 / 8
# of cores4
Graphics CardNVIDIA GeForce GTX 470
# of cards1
SLI / CrossFireOff
Memory1280 MB
Core clock675 MHz
Memory clock1701 MHz
Driver nameNVIDIA GeForce GTX 470
Driver version8.17.12.6099
Driver statusFM Approved
Operating system64-bit Windows 7 (6.1.7600)
MotherboardMSI MSI X58 Pro-E (MS-7522)
Hard drive model
Memory6144 MB
Module 12048 MB Corsair 9 @ 667 MHz
Module 22048 MB Corsair 9 @ 667 MHz
Module 32048 MB Corsair 9 @ 667 MHz
3DMark ScoreP4662
Graphics score4348
Physics Score8019
Combined Score4294
GraphicsTest118.8 FPS
GraphicsTest219.71 FPS
GraphicsTest327.18 FPS
GraphicsTest414.11 FPS
PhysicsTest25.46 FPS
CombinedTest19.98 FPS
ProcessorIntel Core i7-920 Processor
Processor clock4000 MHz
# of cores4
Graphics CardGraphics CardATI Radeon HD 5870
# of cards3
SLI / CrossFireOn
Memory1024 MB
Core clock400 MHz
Memory clock300 MHz
Driver nameATI Radeon HD 5800 Series
Driver version8.801.0.0
Driver statusNot FM Approved
GeneralOperating system64-bit Windows 7 (6.1.7600)
MotherboardASUSTeK Computer INC. P6T6 WS REVOLUTION
Hard drive model
Memory12288 MB
Module 12048 MB OCZ 9 @ 533 MHz
Module 22048 MB OCZ 9 @ 533 MHz
Module 32048 MB OCZ 9 @ 533 MHz
Module 42048 MB OCZ 9 @ 533 MHz
Module 52048 MB OCZ 9 @ 533 MHz
Module 62048 MB OCZ 9 @ 533 MHz
score: 3640
not bad for what I have:
Phenom X4 955 @ 3.42Ghz
8GB DDR3 1600
AMD 6850 @ 900/1000
Being totally bored tonight I just tested with only two 5870 and added a Nvidia 9800GT as a physics and got a higher score then using three 5870s. Got P7834.
I been having some issues with tri 5870s with flashing black screens in BF:BC2 and other weird artifacts that occasionally crops up. It seems that 3DM11 only really support two cards for video.
Name Cancel
Description
Description Cancel
ProcessorProcessorIntel Core i7-920 Processor
# of cores4
# of cards2
SLI / CrossFireOn
Memory1024 MB
Core clock157 MHz
Memory clock300 MHz
Driver version8.790.6.2000
Hard drive model
Memory12288 MB
Detailed scores3DMark ScoreP7834
Graphics score7958
Physics Score8248
Combined Score6572
GraphicsTest143.35 FPS
GraphicsTest241.33 FPS
GraphicsTest348.45 FPS
GraphicsTest420.96 FPS
PhysicsTest26.19 FPS
CombinedTest30.57 FPS SettingsDefault settings usedYes
EditionBasic
Screen Width1280
Screen Height720
Msaa Sample Count1
Max Af Anisotropy1
ShadowMapSize5
Enable WireframeOff
nice, seems the 460 and 6850 are getting pretty equal results...but again this "scores" are all about CPU's, even if we get 100FPS+ in some games on shear processing power.
For sure, the HD6850 and GTX460 are the same class of card. In fact while the 460 might have a slight overall performance advantage the HD6850 is more power efficient so on a performance per watt analysis the 6850 is actually a clear winner.
And yes, cpu appears to be very important. I'm in the middle of putting together another rig for my bedroom that will be made up of a e8400 (@4Ghz all going well) and a HD 6850. It will be interesting to see what it scores.
Just thought I'd update this.
So I ran a compare between my Q9400/GTX460 rig and my e8400/HD6850 rig.
The Q9400 is clocked at 3.7Ghz and the card at 850/1000Mhz
The E8400 is clocked at 4.2Ghz and the card at 900/1050Mhz
Both systems are running a 470(1880Mhz) FSB with memory at 1:1
These overclocks are stable and what I've tuned both systems to run at on a daily basis.
The results are a little suprising:
Q9400 = P3698
E8400 = P3675
http://3dmark.com/compare/3dm11/375018/3dm11/369186
The only reason the Q9400 wins is it has better physics results, but the frame-rates mostly go slightly in favour of the HD6850
So I have to say, on the balance of power;performance and cost, the HD6850 is a clear winner.
As an aside, both my rigs have xfire capability and I recently found out they can run sli with this patch http://xdevs.com/e107_plugins/conten...php?content.30
So I can see myself taking this battle to a SLI/Xfire setup at some point
ps. 3dmark seems to have trouble acquiring the cpu details on my e8400. I wonder if it is because it is clocked so high?
SLI is now supported.
Score is now 8731
3DMark Score P8731
Graphics score 9122
Physics Score 8388
Combined Score 6933
GraphicsTest1 39.52 FPS
GraphicsTest2 41.53 FPS
GraphicsTest3 56.93 FPS
GraphicsTest4 29.5 FPS
PhysicsTest 26.63 FPS
CombinedTest 32.25 FPS
With the catalyst upgrade from 10.12 to 11.1 my score went up from 3640 to 3852, still no 7000+ due to my CPU's 4 logical cores but it's decent enough at least for me
http://3dmark.com/3dm11/650668
1 - 20 of 25 Posts
