1 - 2 of 2 Posts
If I want the ability to transcode 4x HD DVB-T/S streams at the same time as I'm viewing one or two using the system outlined below...
Could I get away with doing all transcoding in software with minimal performance degradation & quality compromises?
How does one go about calculating for themselves?
Gigabyte GA-P35-DQ6
Antec TruePower 3.0 650w
Intel E6420 2.13Ghz ----------------------- [Core2Duo;Conroe]
Generic 1GB DDR2-800 (PC6400) -------- [Will upgrade to 4GB+]
DNTV Live QuattroS Dual-Hybrid DVB-T/S [This will be replaced with something linux compatible]
Asus EN8600GTS 256MB DDR3 ----------- [HDCP]
The following SATA 1.5/2 drives:
-1x 1TB WD Caviar Black
-1x 250GB Seagate ------------------------ [I think? YTBD]
-1x 150GB WD Raptor
-1x 74GB WD Raptor
Cards that do analogue capture but without on-board encoding sound more ideal:
http://www.mythtv.org/wiki/Video_cap...Types_of_cards
If the config. above is far too weak then I'll just have to be less ambitious...
The PVR componant will move into a VM on a bare-metal hypervisor server later-on anyway, this will be a much more powerful system.
Advice/knowledge greatly appreciated!
Cheers
1 - 2 of 2 Posts
