Hi,
I just bought a Pioneer VSXD711; manual says "use speakers with a
nominal impedance of 8ohm to 16ohm" - the continuous power output
is 100W per channel (5 X 100).
I already have the old Bose AM6 cube speakers; the manual says
"compatible with A/V receivers rated from 10 to 100Watt per channel;
rated from 4 to 8 ohms". I would like to keep these speakers
for a little while (and just add a active subwoofer).
My question is, what does the range on impedance mean (do the speaker
and receiver need to have same range?). Since they both meet at 8 ohms
is it going to be fine? OR will it create problems?
I usually play music at moderate volume (not too low and not too high).
Murali.
Murali.
