1 - 11 of 11 Posts
Premium Member
So, I have 4 LMS Ultras, 3 working and one that needs the basket changed out and I can't be bothered selling them so I though I may as well put them to good use, I was thinking of making 4 triangle shapped boxes and putting them in each corner of the room. My question is , will the shape of the box affect sound quality or is volume all that matters?
Cheers
Originally Posted by JapanDave  /t/1521193/4-x-lms-ultra-18s-in-triangle-shaped-box/0_100#post_24445202
Cheers
Short answer, no, it won't matter in a small sealed box like this.
Premium Member
Discussion Starter · #4 ·
Originally Posted by notnyt  /t/1521193/4-x-lms-ultra-18s-in-triangle-shaped-box#post_24445255
Thanks. Yes, I thinking sealed BTW.
Originally Posted by aaronlinkous  /t/1521193/4-x-lms-ultra-18s-in-triangle-shaped-box/0_100#post_24445259
So it would matter if it was ported?
Not necessarily. Would most likely still be better than square, but with ported you have to deal with a larger enclosure, which means earlier resonances.
Originally Posted by Scott Simonian  /t/1521193/4-x-lms-ultra-18s-in-triangle-shaped-box#post_24445399
You will give them to me.]
Ah you're good Scott!
Premium Member
Discussion Starter · #8 ·
LOL... I will give them to you.
Bass Enabler
Originally Posted by bass addict  /t/1521193/4-x-lms-ultra-18s-in-triangle-shaped-box#post_24448836
What you meant to say is;
Ahahahaha!
Originally Posted by JapanDave  /t/1521193/4-x-lms-ultra-18s-in-triangle-shaped-box#post_24448789
Damn right you are.
1 - 11 of 11 Posts
