I bought a Toshiba 40H80 a few years ago and I am finally able to view High Definition material. Woohoo! The ability to do so, however, has underscored a problem I've had with the set that is almost unnoticeable with SD material (including most DVDs), but glaringly obvious with HD. I'm hoping someone here could tell me what I'm seeing and what I can do about it.
I'm not a pro at this so I'll try to explain it in layman's terms. What I am seeing is slight ghosting to the left, much like what you would see in the good old days when the only way to get reception was via an antenna. This ghosting appears about an eighth of an inch to the left of any high-contrast image on the screen.
Now this is not edge-enhancement that I'm talking about. It is not as if the ghost has any color to it or is program-dependant. It is always present.
As I said, it is hardly noticeable with SD material, but I'm watching the masters right now in HDTV and it is obvious to the point of distraction! Every flag, every club, every caddy/golfer silhouetted against the lush green grass or blue sky has this faint mirror image/halo just slightly offset to the left!
So what I want to know is: What is causing this and how the heck do I fix it? I have not had the set ISF'd, simply because I have not been able to justify the cost given the fact that SD material looks pretty darn good. But the crispness of HDTV only emphasizes it.
A follow-up question would be: who in the Washington DC area would you recommend?
Thanks in advance!
Chris
Thanks in advance!
Chris
