42PWD6UY Problems eliminating the excessive Blue Tint.
259 Views 4 Replies 3 Participants Last post by  HuskerHarley
I've had my Panny for over a year now and I've tried just about every recommendation/setting and even had it ISFed (he screwed everything up) trying to achieve as good of color/picture as my old Sony 32 XBR-squared and I'm still not able to obtain that last piece of the puzzle.
One of the most annoying things about this Panasonic and it's also on one of my neighbors is the fact that in some/a lot of scenes there is an overabundance of the color blue it's really noticeable when a scene is in black and white it seems more like light blue and dark gray.
It also shows up when viewing ordinary television programs you tend to notice that the majority of everything has a bluish tint to it.
Have any of you other long-termers with the Panasonic's noticed this problem?
How about a fix for the tint.
Harley
Status
Not open for further replies.
1 - 5 of 5 Posts
This is a post from the Jersey Shore Sootout which may give some insight on why Panasonic panels may exhibit a blue bias: but proper calibration should take care of it:
01-27-03 06:14 AM
ghibliss
Brucer,
The reason that the plasma panels need to be "re-tuned" after 1,000 hours is due to the fact that the Blue phosphor wears at a faster rate than the Red and Green phosphors. This wear is supposed to be at a fairly linear rate but has shown to have a very measurable effect on the White Balance of the panels. The Panasonic glass has an assymetrical phosphor design which means that the Red and Green phosphors are the same size but the Blue phosphor is slightly larger to compensate for the higher rate of wear that it will undergo over a period of time.
Since the Blue is wearing faster this will make the image shift and become slightly Red. Once the panel has been calibrated the user can compensate for this eneven White Balance by simply adding a few clicks of Blue to the Integrator mode or User Custom White balance settings in the software and the color temperature will track accurately once again.
I have now measured and logged the results (done with a spectroradiometer) of a number of customers panels with data from new to over 2,000 hours of use. The rate of wear is consistent for a given model over the same time period and re-calibration is generally the same amount of offset from one panel to the next.
__________________
See less See more
Husker,
Have you tried the "warm" color temp setting? That certainly goes a long way to change the cool factory-set (blue) color used in the "normal" mode.
Perhaps as a good starting point?
Originally posted by R Harkness
Husker,
Yes I'm currently using the "warm" setting which helped a little but overall the blue tint is very noticeable.
Husker
See less See more
I agree, some days I will spend literally hours tweaking the set and obtaining about 90 percent of what I'm after and that other 10 percent drives me crazy...
Also up above it almost sounds as though in time you would lose the blue and gain a red push.
My set is approximately a 1 1/2 old with some days being turned on early in the day and going till late at night, so I'm sure I have put an extreme amount of hours on its short lifespan which is probably having some effect on something that I just can't get my hand on to make the proper adjustment.
Husker
See less See more
1 - 5 of 5 Posts
Status
