A buddy brought me his 4805 to look at.
I took it apart and the bulb fan is broken. The shaft broke and needs to be replaced.
How do you get it out?
I took the top two screws off and thats all there are. Seems to be a mounting tab at the bottom but I did not want to force it.
Looks like a simple replacement if I can get the fan out. Do I need to take the power supply board out?
