4805 installation problem
943 Views 2 Replies 2 Participants Last post by  KeithfromCanada
Hi all.
I ceiling mounted my 4805 yesterday and found that I instantly had a trapezoid image. All I did was ceiling mount the PJ, level it and set the keystone to 0. In order to get a straight image, I needed to set the keystone to 40!!!
I understand that the PJ has offset but I would have thought that mounting it and making sure it was perfectly level would mean that the image would be perfectly 16:9. Did I do something wrong or is this an issue with the PJ?
1 - 3 of 3 Posts
The default number is 50. 40 means your wall / screen is a little bit off of plumb.
Many thanks for the reply!
So 50 is actually 0? Interesting.
I had only mounted the top brackets on the screen...I guess I'll be careful while mounting the bottom.
1 - 3 of 3 Posts
