Status
Not open for further replies.
1 - 2 of 2 Posts
I have the Pioneer Elite 530 model....does it matter which setting I use....480i or 1080i?
Mike
I'm not sure what the Elite 530 model is, but my answer is yes, it does matter. Is the source output 480i, 720p, or 1080i? Pick the wrong one and you are likely to just get static. If the Elite 530 is the source then pick 1080i if your display can handle it.
1 - 2 of 2 Posts
Status
