Just a myth, 4 ohm speakers are fine on almost any amp and any of it's outputs. Some HT in a box type amps are designed for 16ohm speakers but any run of the mill amp is fine.
Cheaper to try the current amp first.. If it works well it will save some $$ .. If not then it's time for a new receiver..Instead of ditching the speakers, why not get an amp that can drive 4 ohm loads? If the Yamaha V6A manual says to not use 4 ohm speakers, I wouldn't do it.
KEF LS50s are rated at minimum 3.2 ohm (4 ohm speakers) and they play just fine with and 8ohm receiver. The 8ohm rating for receivers are mostly for regulation purposes. To have and 4 ohm rating the receiver would have to be able to put out a stable load at 4 ohm RMS. This is quite hard and requires a rather beefy power supplyIMO, you have to be a little careful powering 4 ohm speakers with an amp or receiver not rated for 4 ohms. You may be fine most of the time, but you may have problems, especially if you like to play the speakers very loud, depending on the specific amp and the specific speakers. I disagree with a blanket statement that you will never have a problem.
Just wondering if anyone has any advice?
If by "work" you mean sound will come out of the speaker, then I agree.KEF LS50s are rated at minimum 3.2 ohm (4 ohm speakers) and they play just fine with and 8ohm receiver. The 8ohm rating for receivers are mostly for regulation purposes. To have and 4 ohm rating the receiver would have to be able to put out a stable load at 4 ohm RMS. This is quite hard and requires a rather beefy power supply
Playing a 4 ohm speaker with an 8 ohm receiver will most of the times just work fine![]()
yes a cheap receiver will not do them any justice at all but a better receiver yet with 8ohm rating will work great. Marantz sr7012 (my receiver) drive LS50 without a problem at all and they sound great even at high volumeIf by "work" you mean sound will come out of the speaker, then I agree.
But if you are looking for the most (best sound) out of the speakers then you need a proper amp match for them. A cheapo 8ohm receiver won't show what a speaker like the LS50 will do. Pretty much every review of demanding speakers like that all say the same thing in terms of amp selection.
So will it work? Yeah, probably will. Will it sound its best? Probably not. Note that inexpensive Yamahas are plagued with somewhat inferior amp sections, hence the warning about 4 ohm speakers plus the 8/4 ohm switch on the back on some of them.
The LS50s are rated at a nominal impedance of 8ohm. If it spent any notable amount of time in the 3-4ohm range, they would have indicated a 4ohm nominal impedance in the specs.KEF LS50s are rated at minimum 3.2 ohm (4 ohm speakers) and they play just fine with and 8ohm receiver. The 8ohm rating for receivers are mostly for regulation purposes. To have and 4 ohm rating the receiver would have to be able to put out a stable load at 4 ohm RMS. This is quite hard and requires a rather beefy power supply
Assuming that the major AVR companies employ competent engineers to design their products -- which I do -- I doubt that there is an AVR around that can't work well with 4-ohm speakers. Additionally, worst-case engineering should provide for ample phase margin at 4-ohm loads to protect the amplifier.The 8ohm rating for receivers are mostly for regulation purposes. To have and 4 ohm rating the receiver would have to be able to put out a stable load at 4 ohm RMS. This is quite hard and requires a rather beefy power supply
I tryed my LS50/Metas with my cheap Sony STR 1080 receiver, and yes it works, but the sound is far from a dedicated 2 channel amp!, in fact my old Kef 3005 sattelite egg speakers sound just as good if not betterIf by "work" you mean sound will come out of the speaker, then I agree.
I'd ignore the doomsayers and just try the 4 ohm speakers with your receiver to find out FOR YOURSELF whether it's a go or not.Thanks everyone for the discussion. If I am able to purchase an amp, at best it will be a V6A equavilent, or maybe only the V4A or 485. That's at the best.
Personally I'd like to be using my bookshelf speakers, but my wife finds them ugly so form wins. I may consider wraping them in some 4mm ply and having my mate polish them to match the cabinet and coffee table. That could win her over.
