Originally posted by b2bonez
Odd that you should come up with the 2:1 ratio that most theaters use
that were built from the mid '80s on. The OAR evangelists would
condemn your compromise as heresy, but sometimes by giving up a
little you can gain a lot in other ways. |
Interesting I didn't know that movie theaters use 2:1...hmmm
Originally posted by Rob4x20
I have a 7x9' piece I was going to cut into a 60.75"x108" for 1.7777 ratio. But you think it's better to do 54x108"? |
Yes I think so, because I find 2:1 to be the best screen AR for
movies. Keep in mind I use my HT for two things: watching standard definition TV and DVD's. If I had HDTV, a 2:1 screen would probably not be the best choice.
Just to be clear, that means the 2.35s would zoom in and cut off some of the sides? While the 1.85 would zoom out and cut some of the top off? How many inches? I'm confused....  |
You're not confused, you're correct.
How many inches cut off depends on the size of your screen. If you had a 54x104" screen, and you zoomed a 1.85 movie so that it completely filled the screen (this would be a 56x104" image), you'd lose one inch off the top and bottom. That's 2% off the top and 2% off the bottom. Will you notice that? I never have.
On 2.35 movies, after zooming it to fill the 54x108 screen, you're losing 9.5" on the left and right. I don't mind this at all, because there's never anything much going on in those extreme far edges. You don't miss them, and the perfect edge-to-edge masking can't be beat.
Also, what happens to HDTV? I have a set top box for this as you mentioned. Could I not just zoom and have unused screen areas? They'd be on the sides, right? |
If you have HDTV, you may want to think twice about going with a 2:1 screen. HDTV is 1.78:1 and if you're viewing it through a set-top box and not an HTPC, then you're going to have to zoom/unzoom every time you switch between watching DVD's and HDTV. Not worth the hassle in that case.
Originally posted by Lord British
Thanks for the replies everyone - to tell you the truth, I'd rather not cut my screen if I don't have to.
mbaxter - I don't have an HTPC right now but I was planning on building one in the very near future... I am a bit confused by your post though...
so I don't cut the screen and still put the 2 inch black border all around.. so wouldn't my screen now have a 44" x 92" viewing area which is no longer 2:1?
and then I have to use a program like TheaterTek to fill the screen.. does this distort the image at all or just zoom it which causes it to lose a little picture as you stated?
and like Rob4x20 asked, what happens with 1.78 HDTV that is left untouched? |
I wouldn't want to cut a Parkland either.
Those things are a major PITA to cut manually.
To get exact 2:1 AR I would just use 2" masking on the sides and 1" top & bottom, giving you a 46x92" screen.
The nice thing about playing DVD's through a computer is that you have such outstanding scaling capability. Good software players like TheaterTek and Zoomplayer can do this without any quality loss.
BTW, I should have made something clear in my first post. To use a 2:1 AR screen, you need to have everything run through the computer, and the computer should have PowerStrip installed so that it can output a true 2:1 resolution. For example, my system runs at 1024x512. TV, VCR, DVD, Windows, everything goes through the PC and enters the projector via the same VGA cable. Thanks to the HTPC, all types of output are confined to the 2:1 area defined by PowerStrip's 1024x512 custom resolution.
This is why I don't mind a 2:1 screen. If I was using any set-top boxes, the 2:1 screen wouldn't work.
