1 - 9 of 9 Posts
also todays specials from Newegg
three pairs, then add a subwoofer http://www.newegg.com/Product/Produc...AFC-C8Junction
or start with a pair of these M70 towers ($20 each off coupon SPEAKER82X2) in a 2.0 system http://www.newegg.com/Product/Produc...AFC-C8Junction
and build up as the budget allows adding a center Polk CS2 http://www.newegg.com/Product/Produc...82E16882290023 and M30 surrounds when the budget allows, along with a subwoofer of your choice.
Discussion Starter · #6 ·
Originally Posted by afrogt /forum/post/17039125
Look at this thread, same questions as yours....
http://www.avsforum.com/avs-vb/showthread.php?t=1172075
BIC f12 sub how good it is? never heard the brand.
how is this speaker combine with the above sub?
energy take classic 5.0
and how about energy c50 with bic f12sub instead of esw v8 sub?
Discussion Starter · #7 ·
Anyone?
I think it depends on what you're looking for. The BIC F12 will play lower than the V8 sub. If home theater is your primary purpose and you have a fairly large room, go with the F12. If instead you play a lot of music, go with the V8 as it will be a more musical sub. it probably mates better with the Energy speakers where the satellites stop producing bass too.
Can anyone comment on, comment against, or recommend a center channel speaker upgrade? I have Yamaha NS-SP7800PN powered by a Denon AVR-1900 (790). I'm looking to add some more personality, ummph and strength. I'm in an two family unit so it's rare when I have the chance to turn the volume up where I like it. My Yamaha NS-SP7800PN does a nice job, but I want more. I want more, but at the same time want the system to remain "matched." If if should post this elsewhere can you suggest where that would be?
1 - 9 of 9 Posts
