Hi everyone. I've been reading what is available using the search feature and must say there is a metric ton of information here.
Quick question to ask if there is any article or how to guide for setting up a 5 or 7.1 home theater?
Problem is that I'm already wired for ceiling speakers. Based on our seating layout it is actually pretty correct based on what I've found here so far to include a sub woofer connection. I have a pair of floor standing speakers, ESS Tempest Classics, but am not trying to incorporate those into the design at the moment. I'm a bit spoiled by their clarity with highs but have to say they are on their last leg and I am out of spare heil tweeters
With that being said I usually am playing physical media and watching movies. Movies probably a couple times a week. I am actually looking for a building block approach knowing I'll spend a bit more now for the receiver and sub woofer than the initial 7 speakers up front that I could probably replace later.
What I'm not sure about since I'm using in ceiling speakers is if people match for each location or mix. Or, if it doesn't matter as much and find something with good tonal quality and adjustable tweeter/highs and use a proper matched sub. I think that is what I am struggling with now
