I am building a 5.1 home theater setup for primarily blu-ray movies/Xbox 360 with a tiny bit of music (XM was the reason I think I will go to the Pioneer VSX-1018AH-K Receiver over the Onkyo TX-SR606B). This system will be used for 90% movies/tv/xbox and 10% music/xm radio/ipod. It will be for a smallish-medium sized living room in my 3 bedroom 1600 sqft condo.
THE CATCH - Everything must be ordered from www.onecall.com . I have a $1000 gift certificate and can get a few $200 gift certificates if I need to run a little over budget. Onecall's speaker selection is not the greatest. They have very few complete home theater systems (5 speakers + 1 sub) available, so I may have to put it together piece by piece, which is fine. I don't mind if speakers aren't tiny.
Thanks for any help you can provide. It seems like most advice for a budget system involves brands that aren't available from Onecall, which is why I've felt the need to start my own thread.
My receiver: http://www.onecall.com/ProductDetails.aspx?id=92871
Worth $100 more to go with Onkyo TX-SR706B? http://www.onecall.com/ProductDetails.aspx?id=91171
The speakers...
By brand, they have...
Brand (# of speakers for sale) - I've included a few links
Audioengine (7)
Bose (31)
Boston Acoustics (80) - Home theater system CS2310B here http://www.onecall.com/ProductDetails.aspx?id=92871
Definitive Technology (63)
Infinity (38) - http://www.onecall.com/ProductSearch...=p_CartPrice|0
KEF (78) - http://www.onecall.com/ProductSearch...=p_CartPrice|0
Klipsch (86) - http://www.onecall.com/ProductSearch...=p_CartPrice|0
Mirage (25)
NHT (19)
Niles (71)
Polk Audio (95) - Polk Home Theater Systems http://www.onecall.com/ProductSearch.aspx?N=380+1161
I don't know if I should go with a set of 5 speakers (adding a sub if not included) or get something like 2 open box floorstanding speakers (ea $239.97 + $25 shipping Polk Audio RM40T) and then add the other parts as $$$ permits. http://www.onecall.com/ProductDetails.aspx?id=88360
I realize that for this limited budget may would say just shop used craigslist, but since I can get the gift certificates relatively easily, it seems dumb not to try to use them.
Onecall's Receivers ($300-$600) http://www.onecall.com/ProductSearch...=p_CartPrice|0 Finally, I realize that it's a different forum but I'd take any advice regarding my receiver as well.
Appreciate any suggestions.
The speakers...
Audioengine (7)
Bose (31)
Mirage (25)
NHT (19)
Niles (71)
