Status
Not open for further replies.
1 - 2 of 2 Posts
Do I have this right? In order for my 5040 to know wether to use input 1 or 2 I have to tell it thru setup. I have my analog cable on Input 1 and my SAT on input 2. I seems that the only way I can receive local stations (cable) or movies (SAT) I have to switch it manually thru setup in order for it to work.
Nope. Configure it so your cable is on the ANT/CATV input in setup.
You'd only use "Input 1" for cable if you have an external cable box... using the A/V RCA jacks.
1 - 2 of 2 Posts
Status
