Status
Not open for further replies.
1 - 2 of 2 Posts
I'm having some show transfer problems. I've requested a few shows from PlanetReplay while at work. The person then attempts to send the show to my 5040. Unfortunately I can't accept the show until I get home from work. This usually seems to cause an "Experiencing network errors. Check your network connection" error.
If I have the user resend the show and I accept it a short time later the transfer works fine.
Is there some sort of timeout where a show must be accepted within a certain time period after the transfer is initiated in order for the transfer to work? I don't recall seeing this in the manual.
1 - 2 of 2 Posts
Status
