1 - 3 of 3 Posts
· Registered
Anyone have any idea what this means? I get no picture, and can't even seem to get the TV on. I have consulted the manual, but it doesn't have any information about any error lights, or even anything about replacing the bulb (which I have a feeling is the problem).
Thanks in advance!
-Erik
· Registered
Thanks in advance!
-Erik
If memory serves me correctly, I believe that it is saying your lamp door is not secure. Unplug your set for a few minutes, and then open the door and close it again tight. Plug in your set and cross your fingeres. If this doesn't help, then you could have a bad switch. Good luck to you.
1 - 3 of 3 Posts
