Ok, the issues described below have disappeared and are not reproducible now. What to do? I hate to have another unit delivered if this one is ok, but earlier the problems were severe and easy to reproduce. Could it have been a temperature issue, and now that the set is room temp I will never see those issues again? Or, should I just play it safe and get the replacement the seller has scheduled to have delivered? Help me make the right call. Thx
Took delivery today, and wouldn't you know I got a bad unit. Let it come up to room temp for a couple of hours before I even plugged it in. Turned it on, saw half the backlight disappear during the first 5 minutes of viewing. Then I lost the image altogether, and I mean not even the TV menus would display. I called and have a replacement unit scheduled for delivery.
I have it running fine now, and the weird thing is, the backlight thing is reproducible. I can tap my heel on the floor while in my viewing chair and one or more of the backlight zones will turn off. 100% reproducible on demand. Must be a loose solder or a whole bunch of loose solders. The replacement TV is from the same shipment, so I have my fingers crossed.
Bummer aside, the image fidelity is great and if I had one that worked I would be thrilled with this set.
