Ok, so I am helping a friend build a HT setup for $5K. He is pre-wired for 7.1 (Zone 2 wired to patio) and already has a Samsung 65” LED for viewing. His room dimensions are approximately 18’ x 18’ with no type of acoustical treatment. I understand $3K isn’t much to work with for a multi-zone A/V Receiver and 7.1 surround, but I need some help from you guys because all of the equipment that I normally research is a bit out of his price range. Don't worry about the Zone 2 speakers as he will be purchasing them seperately, we just need to ensure the A/V Receiver is multi zone capabable. Details below.
Equipment Desired:
*A/V Receiver: 9.1 / Multi (2) Zone / Wifi (Control w/iPhone) / Audussey XT32 (not 100% Necessary)
*L/R Mains
*Center Channel
*Surrounds
*Subwoofer
Goals:
*90% Movies 10% Music
*Best Bang for the buck output and clarity
*Wifi/Bluetooth/Wireless Control Options
*WAF is important (to a degree)
Limitations:
*No in-walls or ceiling mount speakers
*No LAN wired to his AV Rack, so he will need Wifi
*DIY is NOT an option
*$3K MAX (no flexibility)
This is what I am thinking thus far:
*A/V Receiver: Denon 4311CI ($1,300)
*L/R Mains: (1) Polk Monitor70 Series II ($500)
*Center + Surrounds: Polk Audio Blackstone TL150 5-Pack (Center + 4 Surrounds) ($350)
*Subwoofer: Epik Empire $800
Total: $2,950
Note how I focused most of the funding on the 4311 (XT32) and the sub. My initial thought was to recommend at least one or two good components, with the rest being relatively cheap. That way if he decides to upgrade he won’t have to change any middle of the range equipment. Also, I figure that the sub is going to provide the most audible impact when watching movies, so just a long as the Polk Monitors and lower end polk surrounds can provide decent output above 120Hz he will be pleased.
When/if he decides to upgrade, adding another Epik would be a breeze and integration with XT32 would benefit him more then he even knows at the moment. I’ll work with him the future if he want’s to upgrade his LCR and surrounds (thinking Salk – way down the road), but for now what do you guys think of my suggestions?
I’m open to other alternatives and input for sure.
*Edit - Update title to show $5K budget and 5.1 set-up.
Equipment Desired:
*L/R Mains
*Center Channel
*Surrounds
*Subwoofer
Goals:
Limitations:
Total: $2,950
