The PCI 2.3 spec says that both 5V and 3.3V are electrically supported on the motherboard.
A PCI 2.3 compliant card should be able to use 3.3V and should be universally keyed, but a PCI 2.3 compliant motherboard still supports 5V keyed cards.
For example, take a look at the MSI 915P Neo2 Platinum which has 5V keyed PCI connectors but is specified as a PCI 2.3 motherboard.
So the Avermedia M150 should work fine with PCI 2.3 spec motherboards.
Having said that, if you want to be completely future proof (PCI 3.0 ready), there are tuner cards out there with universal PCI connectors.
Since you appear to be in Japan, the Novac Home-TV 300H is a possible candidate. While it is a Conexant CX23416 based card, I'm not sure how easy it will be to support via ivtv.
An older, possibly no-longer manufactured card with a universal connector and some success with ivtv is the Kuroto Shikou ITV16-STVLP (Same as Yuan MPG600). The newer CX23416GYC-STVLP does not seem to have the universal connector, although the Yuan version of the same card does appear to.
Krishna.
Krishna.
