Run the 1067 and make sure it doesn't get overly hot at the volume you will be normally achieving. If it never gets too hot, it won't shut down.
Originally Posted by abumuqaatil /forum/post/20826841
Thanks for the reply. After running it loud for half an hour , I put my hand on the grill at the top and noticed it was only warm, but not hot, so I think its ok.
However, my next question is,
1. Will there be reduced power output If i switch the receiver to
6 ohms ? Would the sound come out cleaner perhaps ? Or would it not make a difference. ?
2. Would it be worth my while to change to 8 ohm speakers ?
Thanks in advance.
Originally Posted by schan1269 /forum/post/20826962
MgFred has it backwards...
The amp will create more power if you LEAVE IT ALONE.
The point of a 6(or 4 ohm) setting is to tell the receiver to LOWER its gain.
Essentially, an amplifier is built to only dissipate "so much heat". Heat is a by-product of power production. When you connect 6 ohm speakers you are asking the amp for MORE power. You "could" ask for more power than the amp can effectively cool off, rendering it to go into shutdown.
All a 6 ohm setting is for is to lower the gain, so it will produce the same amount of "safe" power. However, if you leave it alone...and make sure it never gets "too hot", you really are getting the extra power(at the brief instances you really will be asking for it) when you need it.
Originally Posted by MichaelJHuman /forum/post/20829130
I think they reduced pre conditioning to 1/4 power (which is probably reasonable for movies.) But I had not heard they removed the hour.
Originally Posted by MichaelJHuman /forum/post/20829171
Wow, only 1/8 power, and it can cycle off? Why even bother with rules anymore, heh
Originally Posted by M Code /forum/post/20829345
The 1/8 power is like having only 1 channel driven (7/8) in 7.1 AVR..
No surprise since the CEA standards committee is comprised of representatives from Sony, Bose, Panasonic, Samsung..![]()
Just my $0.02...![]()
Originally Posted by bitemymac /forum/post/20829538
This is one of the reasons why I do not want to get an AVR. I hope there are more pre/pro options... preferably from HK and Denon at tangiable consumer pricing.
I have been sticking with pre + older amps from 90's for the honest power output. They were also built much better, as they seem to last all these years.
