Hello,
I would like to have some power amp recommendations. I need at least 7 channels. 8 or 9 channels are OK as well. My preferrance:
1. Minimum 6 channels. Or 7 or even 8 channels of amplification
1. All channel driven 100 watts or more. 120 ~ 150 would be better though not absolutely necessary.
2. Balanced inputs
3. Price range: Less than $2.5 garnd, hopefully less than 2 grand or even 1.5 grand, new or used.
I currently use an ONKYO 805 receiver with an Emotiva XPA 3 for 3 frontal speakers. The rest of the speakers, side surrounds and rear surrounds are driven by the ONKYO. Speakers are all Def Tech, Mythos ST for the front L&R, Mythos 10 for the center, Mythos STS for the side surrounds and Mythos GEM XL for the rear surrounds. My sub is a JL F112. I will be buying a Pre/Pro to replace the ONKYO in the near future and need an amplifier to go with it. It will be driving 4 surruounds and maybe 2 heights. The surrounds + 2 heights = 6 channels. Then later I might add 2 Widths, totalling 8 channels. My room is not big and I don't need huge power. 200 watts/channel is I think overkill. Thank you for your suggestion.
Michaelmorio
2. Balanced inputs
Michaelmorio
