Status
Not open for further replies.
1 - 3 of 3 Posts
Hi everyone!
I have 6 aura shaker 25 Watt, 4 Ohm each.
How can I connect them to the amplifier? This allows impedance of 8 Ohm.
If they were 4 I understood from previous threads to wire them series and that's it! But what happens with 6 speakers?
Thanks for help!
Debbie!
Hi Debbie.
If you connect 3 of the shakers in series, the remaining 3 shakers in series, and then connect those two sets in parallel, you will end up with a total impedance of 6 ohms. Your amplifier should be fine with this.
/FP
1 - 3 of 3 Posts
Status
