I suggest doing the sub crawl and finding a better location in your room for your sub placement. That may very well solve your problems. After trying that you may want to consider buying a 2nd sub for more even bass response throughout the room across more listening positions. Finally, there is downloading REW and getting a mic so you can take measurements and then getting a minidsp so you EQ.
