Looking for advice having a hard time choosing between tcp55st30 and 60pz550 both can be found for around the same price both have pros and cons but reviews seem to point towards the panny for pq and glare issues. i would like a 60in but the tcp60st30 is a bit out of my price range is 5in smaller worth the pq from the lg i'm at 11ft from the screen i'm afraid of screen door effect or poor pq at 11ft. Every one says go as big as you can afford i just dont want bad pq from a entry level plasma. Are they equal in pq i have not seen either set up anywhere. thanks
