Status
Not open for further replies.
1 - 3 of 3 Posts
Which would you recommend buying and why:
Toshiba 65H80 vs. Panasonic 65WX50 vs. Mits 65857
(assuming price is not a big issue).
I primarily will watch Directv sports programming
Thanks in advance
DirecTV offer almost zero sports in HD or 16x9 (occaisonal boxing match). For DirecTV sports you would probably be much happier with a 4x3 set. Now if you were primarily interested in movies I would recommend a 16x9 set. Specifically the Mits. 65857. I have a 55857 which replaced a Panasonic PT-56WXF95. I had nothing but problems with my Panasonic and Sears was unable to get parts to fix it. The Mits. seems like a much better design and at least for me is much better supported by my local dealer (not Sears). Good luck.
Jay
[This message has been edited by jerndl (edited 06-22-2001).]
Satch66,
I think any of these TV will give you a great picture, I recently went throught the same dilema, I choose the Mits because of the promise of upgradability, as you may know the standard for HDTV connectivity is going to change, Mits is the only manufacturer that have come forward and promised a module to make their current TV future proof.
In addition I think the Mits have better picture, but this is my opinion.
Good luck and enjoy.
Stop DFAST.
Boycott JVC!
1 - 3 of 3 Posts
Status
