Status
Not open for further replies.
1 - 4 of 4 Posts
Dear All
My old HTPC in my living room refuse to start, I ended up built a new machine for the HTPC purpose. :D but spent a lot of money. :(
My set up is Intel 3.0 Ghz cpu, Asus 915 MB, 512M RAM, Gigabyte 6600GT, Antec 480W power supply, I finally fire it up last night and hook up with my Hitachi plasma via VGA out.
The best PQ I got so far is with 1024 x 768 resolution, but the aspect ratio is not correct.
I tried 960 x 600, not very good.
Can someone tell me the best settings for the 1024 x 1204 AILS plasma display using VGA.
I will try to connect the new HTPC with the plasma via the HDTV out, I have no idea how to set up for this (what resolution I should chose, etc) (of course I know how to connect the cable :D ). Can somone give me a help, please.
Rocky
i had to mess with the overscan adjustments. i pretty much picked a resolution, then adjusted the overscan adjustment slider left and right until i got what i wanted. i had to try out a few resolutions, and then slide the overscan bar back and forth.
what is ur display native resolution?
try something close to that and use the nvidia display settng to adjust
for overscan.
otherwise..try powerstrip.
move to dvi/hdmi out asap. the resolution is far better than vga or component.
1 - 4 of 4 Posts
Status
