What is the minimum rear and side speaker placement distance from the listener? For example, if the ideal height is about 2 feet above the listeners ear, how far back (and to the sides for 7.1) should speakers be placed? Is 3 feet too close?
What if you are using the Dolby setup IIx configuration? I know you can figure out the distances based on the angles, but what distance is too close??
