I believe I'm on the path to upgrading my HTIB's receiver.. the system I have is an Onkyo HTS780. Its a receiver with only 5.1 analog inputs and spdif (trueHD related)...
I've been reading through the forum and found many threads to get me to this point...
From my understanding.. to get the full trueHD experience (and 7.1 discrete, once more titles have it).. You need a receiver with 8 analog (or 5.1 analog if you only care about the 6 channels) inputs or HDMI v1.1?
My goal is to be able to use all 8 channels once they are used on the HD-DVDs, so I started looking at receivers and came up with a view to pick from..
Is there any real difference in audio quality amongst the $700+ receivers (HDMI) out there and the ones that are only $400 or less.. I realize the more expensive ones probably have more inputs, etc..
Here are the one's I was considering (any of these equivalent/better in audio quality and will work with full TrueHD):
pricey units (all with full HDMI upconversion/trueHD/audio support, all around $750)
Denon 2807
Yamah V1700
Pioneer 82TXS
less pricey ($499-$350 in that order), (some dont pass HDMI audio, but I think all have 8 channel analog inputs?)
Onkyo TXSR674, with HDMI video upconversion
Onkyo TXSR604, audio via HDMI?, no video upconversion?
JVC RX-D412B; audio via HDMI?, Video upconversion
Pioneer VSX-1016TXV: video only via HDMI
My existing speakers are 8 ohm, 110watt, is there any reason why the new receiver should be 110watts or less?
Alot of these units do "upconversion" via HDMI (i think its just the hdmi).. Does this imply, if you are watching an SD station, it will upconvert the signal to 720p? (Dont most TV's /projectors do this on their own?), ie: Any advantages to having this ability in the receiver? ( I will have an upconverting dvd player, and eventually HD-DVD/dual format player).
I will use this with a Mits HD1000U...
I'm also assuming these are all HDCP compliant, meaning if I hook up my cable box and use the receiver as a passthrough, I will be able to view the picture?
Sorry for the mass questions.. but its organized
Thanks for any answers/advice...
Denon 2807
Yamah V1700
Pioneer 82TXS
