Status
Not open for further replies.
1 - 2 of 2 Posts
Is it possible to get 7.1 audio out of a 6.1 Yamaha 5560 receiver by sending the signal through the M-Audio Revolution 7.1 sound card? If not what kind of options, short of buying a new receiver, do I have? Will hooking up a 7.1 amp (does that even exist?) do the trick? What can I do? Thanks for your help.
m-audio: 8 outputs, your receiver: 7 inputs. However, you dont' have to send all 7.1 outputs to the reciever for it to work. Just tell it you have a 6.1 setup in control panel at youwill be good to go. I would say if you already have 6.1..why worry about 7.1? There are no 7.1 audio or dvd formats so you wont hear any difference (from those formats) Drew
1 - 2 of 2 Posts
Status
