1 - 4 of 4 Posts
· Registered
I just ordered the HIS Hightech Radeon HD 4670 IceQ Turbo 512MB 128-bit video card:
http://www.newegg.com/Product/Produc...82E16814161252
It (hopefully) supports HDTV out through a component dongle that does not come with the card, so I need to order one. I found 7 and 9 pin dongles available on ATI's website, but I'm not sure which to order. Does it matter? Will both work? Will only one or the other work? If so, which one do I need?
Thanks in advance for the help.
-d'ler
· Premium Member
7-pin works (I tested).
1 - 4 of 4 Posts
