Status
Not open for further replies.
1 - 2 of 2 Posts
Where can i get the cable that i need to perform the software upgrade?
What is the part number i am looking for? I think it mentioned two different ones on the infocus support website, what are the differences between them?
thanks for your help!
The two InFocus cables you can use for the upgrade are the M1-A and M1-D cables. The "A" cable has an analog RGBHV connection in addition to the USB, and the "D" cable has a DVI-D digital connection in addition to the USB. USB is all you need for the upgrade, but if you want to use the cable for one of your video sources as well you will need to figure out which one you would most likely want. The "A" cable is also $5 less expensive. They are both 2 meters long. They are available from dealers and the InFocus web site at www.infocus.com in the "store" section.
M1-A cable part number: SP-DVI-A
M1-D cable part number: SP-DVI-D
1 - 2 of 2 Posts
Status
