1 - 1 of 1 Posts
· Registered
I wanted to post a pic of this plug but don't see that option. I disasssembled the Toshiba to clean or replace a color wheel. I now have this problem on re-assembly. There is a 3-wire connector sandwiched between the right(light engine) side and the left module with all of the RCA jacks.
Here's the kicker. This connection was disconneted apparently automatically, and blindly to me until after pulling the right module out, after withdrawing the light engine section, due to the really short wiring. So, the access to reconnect it seems impossible. Does anyone know what I am describing? I am stuck.
Also, if you can tell me how to post a pic I will appreciate that.
1 - 1 of 1 Posts
