Status
Not open for further replies.
1 - 3 of 3 Posts
Has anybody had this problem? My picture, when viewed through the component inputs, is fuzzy, full of lines, sporadically blinks, and sometimes disappears completely and I get an error message that states "hd-comp not supportive".
The projector has worked flawlessly since I purchased it in February, and the DVI and s-video still work fine. I tried component from both the DVD player and the cable box, and I tried two different sets of component cables. I used a grounded cube tap, plugged in to outlet with verified polarity to eliminate the posibility of a ground loop (all other gear is unplugged, the cable and satellite feeds are not attached to the wall). I have the same problem in all scenarios.
The component input on the 7800 must be defective. Any thoughts?
1 - 3 of 3 Posts
Status
