(8) Ported Incriminator Audio Judge 21" build
46013 Views 527 Replies 68 Participants Last post by  lukeamdman
Current dual-opposed sealed build with these drivers:
http://www.avsforum.com/forum/155-diy-speakers-subs/2338649-8x-sealed-incriminator-audio-judge-21-build.html
I'm currently building 8 of these:
Outside dimensions with double baffle:
36" wide
28.5" tall
30" deep
(3) 8.5" x 2.625" ports. Port length is ~55".
Net internal volume: 11.72cu.ft
1/2" round over:
Tune came in at 14hz:
All 8 + the Othorns stacked behind the mains:
See less See more
26
  • Like
Reactions: 5
1 - 20 of 528 Posts
T/S specs for the drivers. I will add...I didn't secure/bolt down the driver when getting these parameters, and Ricci told me that will cause the BL to come in a little lower.
Re = 2.8983 ohms
Fs = 31.2837 Hz
Zmax = 64.4377 ohms
Qes = 0.5802
Qms = 12.3192
Qts = 0.5541
Le = 4.2938 mH (at 1 kHz)
Diam = 454.1638 mm ( 17.8805 in )
Sd = 162000.0005 mm^2(251.1005 in^2)
Vas = 142.7929 L ( 5.0427 ft^3)
BL = 25.7591 N/A
Mms = 675.7605 g
Cms = 38.3012 uM/N
Kms = 26108.8594 N/M
Rms = 10.7822 R mechanical
Efficiency = 0.7080 %
Sensitivity= 90.5184 dB @1W/1m
Sensitivity= 94.9278 dB @2.83Vrms/1m
Krm = 28.598E-03 ohms Freq dependent resistance
Erm = 784.948E-03 Rem=Krm*(2*pi*f)^Erm
Kxm = 272.943E-03 Henries Freq dependent reactance
Exm = 525.888E-03 Xem=Kxm*(2*pi*f)^Exm
Ftest = 25.919 Hz
Ftest/Fms = 0.8285
Test Mass used = 308.6900 g (Equal to 61.7 nickels)
Test Mass (Ft=Fms*0.90) = 158.512 g (Add -150.178g for Ft=28.155)
Test Mass (Ft=Fms*0.75) = 525.592 g (Add 216.901g for Ft=23.463)
See less See more
Two are done and I'm applying the Duratex, and @dsl1 CNC cut the baffles for the remaining 6 boxes.
See less See more
6
  • Like
Reactions: 5
Wow 8 of these, your room is going to be insane. The bracing looks great in the cabinet. Subscribed
Initial SPL testing with one cab indicates that with all 8 I'll be approaching 148-150db from 15-20hz!
  • Like
Reactions: 5
Looking good Luke! I can't wait to come up and hear them.
  • Like
Reactions: 1
How big is your room?
Sent from my XT1575 using Tapatalk
Will be fun watching this come together. Subscribed.
  • Like
Reactions: 1
:eek::eek::eek::eek::eek::eek::eek:
Just WOW!!!
  • Like
Reactions: 1
About 2,300cu.ft. 12'x23' with 8ft ceilings.
Same size as mine. I've got two 21s, and it thumps pretty good in there. 8 is just mind blowing...
Two of these ported is producing more SPL from 12-20hz than all 8 could sealed.
These cross over to dual Othorns at around 30hz, so once these ported boxes are finished I'll be around 145db from 14-150hz:
Most I've hit in the room at the LP so far (I use the "max" value so I consider this 147db):
See less See more
4
  • Like
Reactions: 2
Not sure if that's the correct question
How close are your neighbors? :eek:
  • Like
Reactions: 2
Fortunately for me my HT is completely below ground level. You can hear it outside (mostly noises from my house rattling) but I doubt you can hear it once inside one of the neighbors houses.
  • Like
Reactions: 2
Lmao. I bet it's heard quite further than you would think especially at night when all is quiet.
  • Like
Reactions: 1
Crazy bastard! :devil:
  • Like
Reactions: 2
gotta see this ............
  • Like
Reactions: 1
10 if you count Luke's two iPals in the Othorns. :D
It was crazy in there with the 21s sealed, in these monsters....well I'm really looking forward to demo clips. Especially some of the lower stuff.
  • Like
Reactions: 2
"OK guys I'll turn it up for a demo, hang on..."
See less See more
  • Like
Reactions: 5
Your builds make me happy.
  • Like
Reactions: 2
1 - 20 of 528 Posts
