A while back I started leaving my HTPC on 24/7 as I now use it for more than just watching stuff on my projector, its turned into a general media device and I record using sagetv on it. It has a radeon 9600 video card and I'm connecting over DVI. My problem is, everytime I turn on my projector now, I get no signal until I reboot the PC. Its quite inconvenient now because I generally have it recording prime-time shows from 8pm to 11pm, so if I want to watch a movie with it during those hours I have to reboot it and then I miss part of the show I was recording until it comes back up.
And it only happens with DVI-D, using DVI-A/VGA still works fine. I have no other monitor or anything connected over the VGA inputs, only DVI is connected. The PC is not being powered off in between projector uses, its still on during the whole time. The problem is, the PC doesn't "see" the 8700 as connected. If I VNC into it, I can see that it shows no FPD or monitor in the display properties.
Anyone else run into this issue. Or better yet, does anyone else leave their PC on 24/7 and is still able to power up their projector and get a signal over DVI?
