Status
Not open for further replies.
1 - 6 of 6 Posts
Discussion Starter · #4 ·
Thanks for the info.
Now as far as hardware goes, does the presence of a 15 pin output on the reciever mean that it will ouput 8vsb directly? I note that the Dish receiver has such an output. Do any directv recievers have this type of output?
bmel-
I think you will find that no STB outputs 8VSB - only video/audio. If you want to understand what 8VSB is refer to http://www.atsc.org/.
The 15-pin connector you are referring to is the RGB connection to a HiDef TV. The HiDef TV should have at least a set of RGB (Red/Green/Blue+Horz/Vert) connectors or a matching 15-pin connector. On some STB you can output component video or RGB and most newer HiDef TV's can accept the RGB or component video signal.
bmel,
No. 8VSB is the type of modulation used to get the data from the transmitter to the receiver. The data is supposed to conform to SMPTE-310 and most often referred to as the Transport Stream
None that I am aware of. Some of the professional satellite receivers and/or OTA tuners will have a connector for the SMPTE-310.
Wendell
Technical Services Supervisor
MAETV
[This message has been edited by Wendell R. Breland (edited 03-27-2001).]
1 - 6 of 6 Posts
Status
