1 - 1 of 1 Posts
OK for any who have used flex duct, I'm moving a 12" hvac return from floor to a new soffit. Would like to use 12" insulated flex duct, running up back corner inside a false column from the existing floor ductwork, and then turn 90 degrees to run horizontal in a new soffit to a 6x32" diffusor in the soffit.
Can I "bend" the flex duct the 90 degrees I need or do I need to buy a metal 90 elbow? Would rather run one continuous flexible duct if possible.
1 - 1 of 1 Posts
