92" to 106"with a z2 will i lose resolution?
551 Views 3 Replies 2 Participants Last post by  craig john
i have a 92" da lite high power screen now and iam thinking of getting a 106" screen instead,i have a z2 mounted at 12' back and i also sit 12' back will i lose picture quality going to the 106"?
Status
Not open for further replies.
1 - 4 of 4 Posts
You should be able to zoom your image out to 106". Obviously, it will be bigger than your 92" screen, but you'll be able to see the effect of the larger image size on PQ.
My guess is that it will have a negligible impact. Your resolution won't change, but each individual pixel will get a little bigger and less bright. The one thing I would look for is an increase in Screen Door Effect, (SDE). If you can see the pixel structure at 12' viewing distance on the 92", it will get worse as you increase the image size. With a 106" screen, you will be getting close to the 1.5x screen width location that is the minimum recommended seating distance.
Craig
at 12' now i do not see sde,at 12'(my projector is mounted that distance as well) will the z2 be able to fill the 106" screen?
Yes, according to Projector Central, (click on Projection Calculator). Try zooming your projector out to that screen size to be sure.
Craig
1 - 4 of 4 Posts
Status
