Hey all,
I have had this 960 for a month and it is a great set.
I have had no probs with comcast running straight into cable coax.
But i bought the terk hdtvi antenna and have issues.
I cant get any dig channels and i live no more then 10 miles from the towers.
i ran auto search several times and it found 1 channel once. 4.1 ABCHD.
when i tune it is there is no signal.
Twice while move the antenna around the chan came in very clear for 1 second then dropped out.
Is this the dredded tuner problem on the 960?
Or, is it the crappy antenna or location?
I'm using the antenna on the first floor.
there are a few tall trees around me and the nearest tall building is a 12 story that is 4 blocks away.
I only want the ota for UPNHD since Comcast doesn't offer it over cable yet.
Anyone have any ideas?
TIA.
PS the tv was off for about15 hours when i hooked up the antenna and tried to use it.
TIA.
