1 - 3 of 3 Posts
Maybe the mods here can make this a sticky since the real howto is not listed in the oppo 970 hd brain dump thread and people can get some quick info here.
Ok I was able to burn the iso image to the cd ,and then I loaded the cd into the 970 thenit said load and after that it ejected the cd then there was a countdown in the display window and then the cd just reloads .
Did I do something wrong or miss a step?
Please any info or input will help.
Follow up :
The hack worked flawlessly it seems that once the cd is inserted and once the firmware is installed the cd pops out to give you time to remove it and a counter is diplayed on the front panel and after the cd is removed the player closes the door and that's it.
As for the picture quality I was floored by it ,this dvd player's picture buries the upconverted picture of my samsung hd-841 by a mile ,and the s-video picture was just as clean and clear as anything I have ever seen on a dvd player
Discussion Starter · #3 ·
Yes it did indeed .
1 - 3 of 3 Posts
