Status
Not open for further replies.
1 - 2 of 2 Posts
I get the AIW 9800 Pro card for a PC I put together, plug it into my HDTV using the component inputs and the desktop is not clear. I try the s-video and it is still not as clear as I had expected.
Was is the optimum setting for a Win XP Desktop?
Do I have to get Powerstrip?
At the setting right now, I cannot even access some of the "OK' or "Apply" button at the bottom of windows.
My Mitsubishi WS-65869 does not have DVI, but does have VGA, S-video, and component.
If you're going straight VGA in, I would think powerstrip using Karnis's custom timings might do the trick. s-video isn't going to look very good no matter what.
The thread in this forum is called "REVISED: Custom Resolution Guide for 1080i HDTV-HTPC-POWERSTRIP-RADEON ". I'm too new to post a link to it.
1 - 2 of 2 Posts
Status
