Hello all,
I really need some help. I am having a real problem with bass cancellation in my HT. Right in the main listing position I have a terrible bass null. It is big enough I cannot move my chairs out of the area. So I must relocate my sub (difficult but possible) or do some sound treatments?
Any information or reccomendations you could give me will help temendously.
Room Dimensions:
H=7'6" W=11'2" L=19'8"
Set up.: All descriptions are from seated position facing the screen(16').
Front projection using a 92 x 52 screen. Double doors in the rear of the theater, 2 doors on the left side if facing the screen. All doors are six panel solid. All walls and ceiling are drywall and heavily insulated for sound.
Wall to wall carpet. This room is in the basement with concrete foundation walls behind the front and right side walls.
Speaker setup:
Mains are approx 1" from back and side walls
Center is center 1" from back wall
Sub is between front left main and center approx 5" from back wall. Cross over is set to 80hz.
Surrounds are in back corners of room and are direct reflecting.
I have an additional sub that I am using with the Center channel so I have the center set to large with the sub high pass filter on 100hz.
I have the mains and the center set to "large" on the pre/pro set menu with the crossover set at 80hz.
The problem is like a square in the room that there is no bass at most frequencies. This area is 8' from the front wall, 3' from the side walls, and 2" from the back wall. THis forms a 5' wide by 9' long cancellation area. My seating position is between 14' and 16' from the front of the room.
The bass is set loud enough everything is readdy to shake off the walls, but you can't hear it in the null spot, but you can hear everything rattling.
I have tried moving the sub along the front wall and down the right side wall up to 12' from the front.
Please help me out....I'm ready to give up!
Mark
Room Dimensions:
Speaker setup:
Mark
