1 - 11 of 11 Posts
overflow, filler and waste combo
installed in old tub
12v solenoid and shower mixer, behind a panel in a closet
solenoid on the waste, so plug doesnt need to be inserted
loxone miniserver
result:
Discussion Starter · #6 ·
 this is the unit i used, but i was pushed for time as the plumber was waiting, so had to source locally at a premium. there are better priced options on ebay, from around $50 USD
if i did it again, this is the unit i would use
Hi, very interesting project!
Can you interact with the loxone miniserver by http commands?
Discussion Starter · #11 ·
its the same automation server as mentioned in the first post, the loxone miniserver. www.loxone.com
in the configuration software, you can configure the input to recognise single push, double push, triple push, quad push, and push&hold. timings are all adjustable.
so in the shower for example, i could make that button start the bath / dim the lights / play the "chillout" playlist with a triple click. in fact i might do that
1 - 11 of 11 Posts
