Status
Not open for further replies.
1 - 2 of 2 Posts
I am getting desperate, can someone please tell me what I am doing wrong.
I am using power strip and have not found any way to add 960x540 as a usable resolution.
I have added the resultion under custom resolutions and after every reboot, the 960x540 resolution is no where to be found. My choices go from 848x480 to 1024x768. Nothing inbetween.
I have checked my pstrip.ini file and can see the new resolution being added.
My tv is the Mitsubishi WS65909, Video card is Nvidia GeForce 2 MX 400 (I know it is the not the best video card, but it should be able to do this resolution.) And I am using the VGA port on the back of the TV. I have been able to output 1920x1080 no problem.
1 - 2 of 2 Posts
Status
