Status
Not open for further replies.
1 - 6 of 6 Posts
I am a owner of CS2 and XG751. Here is my problem:
I am using the 480i for the input sourse. If I choose the output is 720p, everything is OK. But, when I choose the output is SXGA(72/75), the size of the picture cannot fully fill the screen(my screen is 90inch 16:9), even I adjust the size to 100%!Please help me to solve this problem, thanks.
It is the video-timings on the CS-2. I have a CS-1 and found that the porches are too high in the default settings of the CS-1. I use powerstrip and then create custom resolutions with the powerstrip settings.
clopez
Is this really the fault of the CS2? My understanding is that the retrace timings on the CRT of computer resolutions such as this are the problem -- in effect, you have to push the projector back to fill the same size screen that a progressive signal such as 720P fills.
Someone please correct me if I'm wrong. Anyway, it sounds like clopez has found a nice work-around.
It sure would be if I'm right about moving the projector (if you want perfect geometry and not a compromise -- compromise can be good, though).
Discussion Starter · #6 ·
Thanks for everybody!I f I choose the output at SXGA(50/60), I can adjust (not using the adusting function of CS2)the size of the picture to fully fill the screen. But, when turn on the cross line pattern of XG751, I found that a lot lines are out the screen.
1 - 6 of 6 Posts
Status
