I am thinking very seriously about getting a new plasma Kuro set for my back tv room, but am concerned about one key point--room temperature.
The problem is that this room does not have central heat or air. It has strip heaters that work fine, as well as the obligatory air conditioner window unit. The thing is--if these units are not turned on depending on what season it is, things can get fairly extreme in the room. In summer if I am gone for a week say, I am not going to leave the window unit running, and it gets damn hot in this room. Same thing regarding cold temp in the winter. I usually turn the heater strips on in the morning. They don't run all the time. So obviously the question is, should I worry about having my set in this room at all?
Thanks in advance for your help.
